My official GM 2005 E Fan post(large pics)
Here it is;
Some After market Cold Air Kit boxes may not Clear the Fan shroud, I only can verify the new style Volant and UPD will clear. Just some info and part #'s for you guys. Perform at your own risk. 2003 SIERRA ELECTRIC FAN UPGRADE 145 AMP ALT P#10464476- Off A 2003 Sierra Denali (**Reman- Delco**) LONGER BELT P#12576451 for use w/stock pulleys If using ASP CRANK PULLEY-gates K060900 6.0L RADIATOR P#DRRA20060 from the barn If you order from the barn No Ac means no engine oil cooler(driver side) A/C means you get the oil cooler. Also it didn't come with a peacock drain. No biggie. Don't forget to trim the Rubber flaps on either side of the radiator. http://memimage.cardomain.net/member...62_28_full.jpg 2005 FANS 2-CONNECTORS P#88987983(might get them cheaper somewhere else) Allen Is now offering them with his harness!!! Awesome. 1-SHROUD P#89023365 ***includes rubber bushings and warning label and motor clips*** 1-BLADE KIT P#89023366 1-BLADE KIT P#89023367 2-MOTOR KIT P#89023368 includes two more clips, ***doesn't come with screws to attach to shroud*** 6-SCREWS FOR MOTORS(14 TAP X 1”L) gm screws are hard to get (The part # for the GM screws are M6.3 X 1.69 X 25MM(L) P#89024887 ) The (#14) screws worked fine and dug into the plastic nice and tight. 2-RAD HOSE CLIPS P#15159494 might already have from stock shroud 2-BOLTS W/WASHERS(8x1.25 x 45mmL)FOR SECURING FAN TO RADIATOR SUPPORT http://memimage.cardomain.net/member...62_38_full.jpg http://memimage.cardomain.net/member...62_45_full.jpg http://memimage.cardomain.net/member...62_46_full.jpg http://memimage.cardomain.net/member...62_47_full.jpg NELSON FAN HARNESS- very nice worry free item. www.nelsonperformance.com pcm trigger= both fans low a/c trigger= one fan on high. pcm trigger with a/c= both high ROCKER SWICTH, (optional) I have it hooked into the pcm lead to manually activate as well. http://memimage.cardomain.net/member...62_37_full.jpg More pics on my cardomain. Total cost almost $820 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Holy Chit Thats a nice cam/springs and retainers with gaskets. It all came out nice though and there's more benifits I think with upgrading to the bigger radiator and alternator. I don't regret it. Just my .2 :cheers: |
Thanks for the write-up, pictures, and especially the part #'s.
We appreciate it! :cheers: |
very nice, 900 is bad considering everything you got
You mean not bad right? ;) |
I included NYS Sales tax as well,
Right around $820 to be exact. |
[QUOTE=creederado]Here it is;
pcm trigger both fans low a/c trigger both fans high pcm trigger with a/c both high ROCKER SWICTH optional I have it hooked into the pcm lead to manually activate as well.[QUOTE] a/c trigger both fans high?. Mine triggers one fan high, which drives me nuts by the way. The A/C cycles a lot! Thinking of tying a thermostat to the AC coil somehow so that it only comes on when coil is hot. Nice shot of the manual switch, I was gonna put it in the same place. Do you see a voltage drop when the fans come on high with the big alternator? Why a larger belt? |
I"ll be installing mine in a couple of weeks. $212 fully assembled brand new fans,$49 for 6.0 radiator off ebay,Nelson harnes WITH correct connectors $89. Total:$350
900 is steep but looks really profesional and you will get better gas mileage. So it will pay off in the end.
will that SHROUD fit the 5.3 rad???
