The manufacturers know what parts shrink or expand and the clearance changes that result. You do not have to worry about this. If it was that easy to design engines we would all be making them.
I would like to go back to the worry that oil falls off the parts when a car is stored or sees long periods of inactivity. For the first oil change in my 575 Maranello I drained the Shell and put in 0W-30 Mobil 1. This was at 775 miles on the odometer. I drove the car home from work, put it on the lift and drained the transaxle and engine oils. I also opened and drained the oil cooler and took off every line that is in the oil system. I wanted to get every speck of the Shell oil out of there. For optimal results you are not supposed to mix synthetic oils of different brands. The system takes 12 quarts with a “normal” oil change but took 15 quarts for this change. It all took about an hour. I then started the engine to check for leaks. The multitude of mechanical engine noises that followed nearly broke my eardrums for about 10 long seconds. Then it was suddenly very quiet. You could hear a pin drop. There was certainly the most possible amount of surface oil on all the internal parts as the engine was only off for an hour. But it was not until the oil circuit primed, filled then sent flow into all the parts that any lubrication was occurring. Hence all oil filters that are manufacturer certified have back flow limiters to keep the oil filter full even with the engine off. Here is an interesting tidbit of information. A 75W-90 gear oil has the same viscosity as a 10W-40 engine oil at 212 and 302 F. Once again, those numbers on that oil can are misleading and certainly add to the confusion I see among automotive enthusiasts. At 75 F gear oils are much thicker than motor oils. There are no start up issues so pour point depressants are not added that minimize the thickening with cooling in gear oils. aehaas Motor Oil 109 Chapter nine. Let’s start over. We have seen that 0W-30, 5W-30, 10W-30 and straight 30 weight oils all have the exact same viscosity at 212 and 302 F. What about startup viscosities? Do 0W-20, 0W-30 , and 0W-40 all have the same viscosity at a 75 F startup. The answer is no. The SAE J300 standard allows for this discrepancy. Here are some examples: ..Viscosity at 75 F startup.. ...0W-20.....0W-30.....0W-40 .....40............50...........60 The numbers are not exact but they show clearly that the ”0” represents different startup viscosities. This is unlike the 0W-30, 5W-30, 10W-30 and straight 30 weight oils that all have the exact same viscosity in a hot engine = 10 cS. I would like to comment on the following statements made by a knowledgeable automotive enthusiast: “Pressure and flow are tied together with viscosity, but none have anything to do with lubrication. Lubrication is a property of the fluid, not the force. The oil pump would pump water just as well, but it would offer no real lubrication. If we double the pressure, we double the flow. If you decrease the viscosity to a lighter oil, you increase flow at a loss of pressure. High flow helps to carry away more heat. High pressure helps to keep metal parts like the bearings out of contact with each other (scuffing).” I give you the following example to help visualize what is happening. This assumes the oil has no internal resistance. In actuality doubling the pressure will not double the flow but will be slightly less. And thicker oils have more resistance than thinner oils for all situations. But simplified we get the following: For a 30 wt oil at operating temperature: RPM....Pressure..Flow 1,000......20 PSI....1 2,000......40 PSI....2 4,000......80 PSI....4 8,000... 160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5 For a 30 wt oil at operating temperature and a higher output oil pump: RPM....Pressure..Flow 1,000......30 PSI....1.5 2,000......60 PSI....3 4,000....120 PSI....6 The maximum flow because of the oil pop off valve at 90 PSI will be 5 8,000... 240 PSI....12 If we stick with the same weight oil and increase the oil pump output we will increase the pressure and the oil flow too. If we double the oil pump output we will double the pressure and we will double the oil flow (in an ideal system). RPM....Pressure..Flow 1,000......40 PSI....2 2,000......80 PSI....4 4,000....160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5 8,000... 320 PSI....16 Let us compare a 40 wt oil at operating temperature: The oil is thicker, has more internal resistance and therefore requires more pressure to get the same flow. RPM....Pressure..Flow 1,000......30 PSI....1 2,000......60 PSI....2 4,000....120 PSI....4 The maximum flow because of the oil pop off valve at 90 PSI will be 3 8,000....240 PSI....8 For a 40 wt oil at operating temperature and a higher output oil pump: RPM....Pressure..Flow 1,000......45 PSI....1.5 2,000......90 PSI....3 The maximum flow because of the oil pop off valve at 90 PSI will be 3 4,000....180 PSI....6 8,000... 360 PSI....12 For a 40 wt oil at operating temperature with the original pressures: RPM....Pressure..Flow 1,000......20 PSI....0.5 2,000......40 PSI....1 4,000......80 PSI....2 8,000... 160 PSI....4 The maximum flow because of the oil pop off valve at 90 PSI will be 3 Increasing the pressure while using the same oil will increase the oil flow but increasing the pressure by increasing the oil thickness will result in less flow. It takes more pressure to move a thicker oil. When you go to a thicker oil the pressure goes up because of the increased resistance, and therefore reduction of flow. There is more to these graphs but I will contiue with the next chapter. Furthermore pressure does not equal lubrication. Let us look at a single closed “lifetime lubricated” bearing. We could hook up a system to pressurize the bearing. This can actually be done. We could have the oil at ambient pressure. We could then double, triple, quadruple the pressure of the oil. The oil is non-compressible. Regardless of the pressure we would have the exact same lubrication, that of the ambient pressure lubrication. The physics of lubrication as I said earlier show a 1:1 relationship of flow to separation pressure. |
Lubrication itself is pressure independent. I will not go into the mathematical equations for this.
Even water can be used as a lubricant. This is partly because of its high surface tension. It is used in many medical devices and other systems that are under or exposed to water. It is just that water rusts metal parts making this unsuitable for automotive engines. It actually has a higher specific heat than oil. It can therefore carry away more heat than oil from bearing surfaces. In this respect water is a better lubricant than oil. aehaas Motor Oil 201 Chapter 10, The graduate. I am going to bring up the constant flow pump concept. First, it goes back to the principal that doubling the pressure of the same weight oil does not exactly double the flow but it is close. Also doubling the RPM for the same reason does not exactly double the flow but again it is close. This shows the problem best: (A) For a 30 wt oil at operating temperature: RPM....Pressure..Flow 1,000......20 PSI....1 2,000......40 PSI....2 4,000......80 PSI....4 8,000... 160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5 (B) For a 30 wt oil at operating temperature and a higher output oil pump: RPM....Pressure..Flow 1,000......30 PSI....1.5 2,000......60 PSI....3 4,000....120 PSI....6 The maximum flow because of the oil pop off valve at 90 PSI will be 5 8,000... 240 PSI....12 If we stick with the same weight oil and increase the oil pump output we will increase the pressure and the oil flow too. If we double the oil pump output we will double the pressure and we will double the oil flow. (C) For a 40 wt oil at operating temperature: The oil is thicker, has more internal resistance and therefore requires more pressure to get the same flow. Compare this with (A): RPM....Pressure..Flow 1,000......30 PSI....1 2,000......60 PSI....2 4,000....120 PSI....4 The maximum flow because of the oil pop off valve at 90 PSI will be 3 8,000....240 PSI....8 (D) For a 40 wt oil at operating temperature and a higher output oil pump: RPM....Pressure..Flow 1,000......45 PSI....1.5 2,000......90 PSI....3 The maximum flow because of the oil pop off valve at 90 PSI will be 3 4,000....180 PSI....6 8,000... 360 PSI....12 The situations (A) and (C) are close to real life, assuming no loss in the system. This is what happens when you change the 30 weight oil to a 40 weight oil in your car: (A) For a 30 wt oil at operating temperature: RPM....Pressure..Flow 1,000......20 PSI....1 2,000......40 PSI....2 4,000......80 PSI....4 8,000... 160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5 (C) For a 40 wt oil at operating temperature: The oil is thicker, has more internal resistance and therefore requires more pressure to get the same flow. RPM....Pressure..Flow 1,000......30 PSI....1 2,000......60 PSI....2 4,000....120 PSI....4 The maximum flow because of the oil pop off valve at 90 PSI will be 3 8,000....240 PSI....8 At 6,000 RPM the maximum rate of flow has been reached with the thinner oil (A). When you go to 7, 8 or 9,000 RPM you do not get any more flow. You only get a maximum rate of 5. The internal forces on the bearings increase but there is no additional flow of oil. With the thicker oil you reach maximum flow at 3,000 RPM (C). Worse yet is that the maximum flow is now only 3. As we increase RPM to 4, 5, 6, 7, 8, 9,000 RPM we get no additional pressure and no additional flow, no increase in lubrication. Next let us look at a 20 weight oil at operating temperature. We get the same flow out of our constant volume pump but the thinner oil requires less pressure to move through the system. This even goes along with the rule that we should use an oil that gives us 10 PSI per 1,000 RPM: (D) RPM....Pressure..Flow 1,000......10 PSI....1 2,000......20 PSI....2 4,000......40 PSI....4 8,000.. ...80 PSI....8 The maximum flow rate has not been reached. If the engine went to 9,000 RPM then the flow would be 9 at 90 PSI, our maximum pressure at pop off. The engine now has 3 times the flow rate as with the 40 weight oil at full RPM. The nozzles at the bottom of each cylinder are spraying 3 times the amount of oil lubricating and cooling this section. Everything runs cooler and the separation forces in the bearings are 3 times higher. For engines that redline at 5,000 RPM they usually pop off the oil pressure at 50 to 60 PSI. For engines that go to 8-9,000 RPM the pressures max out at 90-100 PSI. You can now see that you can only get the maximum flow rate if you follow the 10 PSI / 1,000 RPM rule. The winner: 0W-20 weight oil for my Maranello. I said earlier that I could use a 10 weight oil. I actually only run with 185 F oil temperature around town and the pressures are similar to the 40 weight oil example in (C) above. This is why I also said that in the racetrack condition, with hotter, thinner (0W-20) oil I may actually get the optimal results as in (D) above. Now let us go back to the Ferrari recommended parameters in my 575 Maranello manual. It calls for 75 PSI at 6,000 RPM. The pop off pressure has not been reached. As we now increase the RPM we still get an increase in flow rate. This is what we need and this is exactly what they are recommending. We get our maximum flow at the maximum system pressure, at about the maximum engine RPM of 7,700. There is no bypassing of the oil. All oil pumped goes through the system. There is no wasted BHP pumping oil past the bypass valve back to the oil tank. It is the perfect system. Finally I will compare a single, 30 weight oil, at normal (212 F) and at racetrack (302 F) temperatures: (A) For a 30 wt oil at normal (212 F) operating temperature: RPM....Pressure..Flow 1,000......20 PSI....1 2,000......40 PSI....2 4,000......80 PSI....4 8,000... 160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5 (E) For a 30 wt oil at elevated (302 F) operating temperature. The oil is thinner at 302 F. It requires less pressure to get the same flow: RPM....Pressure..Flow 1,000......10 PSI....1 2,000......20 PSI....2 4,000......40 PSI....4 8,000......80 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 9 The hotter (302 F) 30 weight oil is thinner than the cooler (212 F) 30 weight oil. It has the same flow rate in the constant volume oil pump but at a lower pressure than the oil at normal operating temperature. This allows for a doubling of the flow rate at peak RPM. The thinning of oil at higher temperatures is a benefit. You get more flow, more cooling and more lubrication. The 30 weight oil at 302 F has the exact same flow rate and pressures as the 20 weight oil at 212 F. See (D) above. Therefore, use the 20 weight for around town driving and the 30 weight on the hot track. You get maximum flow at each situation. For YOUR engine, substitute the actual flow at 1,000 RPM. If your engine puts out 1.5 liters/min. at 1,000 RPM it would put out 3 liters/min. at 2,000 RPM and 6 liters/min. at 4,000 RPM and so on. The maximum flow in (A) would be 7.5 liters/min. In situations (D) and (E) you would get a maximum of 13.5 liters/min. |
Conclusions:
The reason that multigrade oils were developed in the first place was to address the problem of oil thickening after engine shutdown. Over the years we have been able to reduce the amount of thickening that occurs. Never-the-less there is no oil that does not thicken after you turn your engine off. This is why we have to warm up our engines before revving them up. Engine designers always pick the recommended oil based on a hot engine and hot oil. There is no issue with oil thinning as they are both matched when hot. The problem is oil thickening when the engine cools. Cold engine showing very high pressures because of the thickened oil at startup: For a 40 wt oil at 75 F at startup: The oil is thicker, has more internal resistance and therefore requires more pressure to get the same flow. RPM....Pressure..Flow 1,000......60 PSI....1 2,000....120 PSI....2 The maximum flow because of the oil pop off valve at 90 PSI will be 1.5 4,000....240 PSI....4 8,000....480 PSI....8 At 1,500 RPM you reach the maximum oil flow rate and if you run to 8,000 RPM it is the same rate. The flow cannot increase and it is insufficient. This is why we must wait until our oil temperature comes up to 212 F or higher. The maximum flow rate in this case will then double, up to 3. To get even more flow in our test engine you need to use a lower viscosity grade. If you have absorbed and digested the information here you should be able to pick out the proper operating oil weight for your car, be it a 30, 40, 50 or even 20 weight oil. I have always used oils that were a grade thinner than recommended even though many use a grade thicker than recommended. I showed evidence that the starting grade should always be 0 or 5 (0W-XX or 5W-XX for thicker oils). If you want the best protection and highest output from your motor use a synthetic based oil. The actual brand is not as critical as the viscosity. The rating must be SL or the upcoming SM rating. Change your oil every 3 - 5,000 miles and at least every spring. THE END |
Holy Crap!!! That's a lot of information. Great find. I like the way he broke down the thicknesses at start up. Perfect timing, as I need to change my oil. Going with 0W-20...we'll see what it does.
STICKY :judge: |
Good read!!!
that was quite a mouthful... put a dent in my morning :D
Looks like a good read but I only get an hour for lunch lol...have to come back and read it later after I put my daughter to bed :nod: There's a lot of great oil info at bobistheoilguy.com also...
I read about 75% of that and couldn't read anymore. Lots of good info there though.
thats just the basics...:eek2:
Thanks guys, I really enjoyed reading it as well. Glad you guys liked it.
