Milling LQ4 heads, whats the max?
Whats the max you can mill a set of LQ4 heads? Exploring my options on this motor to see if I can get 10.5 easily or not. Was looking at maybe running some LQ9 pistons with the milled heads.
Originally Posted by whitt1
I wouldn't mill more than .080.Then I would check piston to valve clearance if you are planning a big cam.LQ4 and LQ9 are basicly the same.
You'll be plenty safe milling .030-.040",you should make about 10:1 compression on a 6.0 block and still have good piston to valve clearance.
If you go to the expence of building the block,spend a little more and add forged pistons.LQ9 are flat top stock pistons that would require dissassembling and honing the block.Why not do things right and do a .030"overbore with forged pistons.Then you can have any compression you want.
