lunati cam
Old Nov 4, 2005 | 09:48 PM
METALMULISHA777's Avatar
Default lunati cam
what dop you guys think about this cam?? any good???? suggestions??
LUNATI cam .. im guessing ill need springs too ...
HYDRAULIC ROLLER: Fair idle. High performance cam. Lots of mid-range torque and upper horsepower
rpm range-2000-5000
adv in/exh- 282*,287*
@.050" in/exh- 218*,221*
@valve in/exh- .526", .534"
@lobe in/exh- .309",.314"
lope sep int C/L- 116*sep, 112*int C/L
opens/closes @ .050 -03*BTC 41*ABC/50.5 BBC -9.5* ATC
"from tybrne motorsports" $299.99 cam ... $114.99 pushrods
Old Nov 4, 2005 | 09:53 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Bit on the small side IMO but would be a good DD cam you would need to look into a 3000 stall to really take advantage of it though.
Old Nov 5, 2005 | 06:17 AM
cool im just lookin for somethin thatl give me a little bit of a lope but i wana make the trip to NH every once in a while... about 3hr drive ..... im open to opinions
Old Nov 5, 2005 | 09:22 AM
Silver-Dollar's Avatar
I was looking at the same cam. I consider the specs middle of the road when comes to cams for trucks. No one is realling going above 224. And 220 seems to be a good number to maintain an under 6200 rpm powerband. The 116 lsa should allow you to still use a power adder in the future. Plus at $300, thats about $50 less than most places carrying Lunatis.
Old Nov 5, 2005 | 03:56 PM
keep the comments comin
Old Nov 5, 2005 | 05:03 PM
99Silver6.0's Avatar
Thunder Racings 220 would be a better idea IMO. Especially if you want to splurge for a converter. Much better cam profiles and much better ramp rates. Maybe even look into Comps 216/220 also. Yes you will want springs and rods. You dont HAVE to do rods but its a good idea while your in there and have the rockers off.
Silver,
I went with a 226 Futral F4. Flyer jumped to a 233/239!!!
Old Nov 6, 2005 | 04:31 PM
thunder racing??
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
