LSA Supercharger on L92 6.2 Denali
How and what parts do I need to do this? Is there a HOWTO thread already I can't find?
I know VVT and AC play a role? I found this kit, is this all I need?
ls conversion brackets-LSSimpleLSA Supercharger 6 groove accessory kit lots of parts has LSS ac option ? LSSimple email mrmurphy@msn.com with desired combonations
I'm starting at zero here. I don't know enough to ask smart questions.
Search around, a few threads with parts you need.
In short here is a list.
Supercharger
S/C Lid assmebly from a ZL1
Blower to lid gasket, large square orange gasket.
CTS-V or ZR1 corvette fuel rail
CTS-V injectors
Intercooler
Intercooler tank
Intercooler coolant lines
Intercooler water pump
Belt system
Serp belt
Catch can
Misc fittings, clamps, hoses or whatever else you may need.
If the supercharger you buy has a factory spring isolator you must replace that with a solid coupler/isolator. If it doesn't come with intake gaskets you will need those and the bolts that hold it down to the cylinder heads.
Supercharger
CTS-V injectors
Intercooler
Intercooler tank
Belt system
Serp belt
Catch can
Supercharger
CTS-V injectors
Intercooler
Intercooler tank
Belt system
Serp belt
Catch can
Supercharger
CTS-V injectors
Intercooler
Intercooler tank
Belt system
Serp belt
Catch can
Speed Inc - Metco LSA Solid Isolator Coupling
Thanks. I'm thinking of going LSA over a EDIT: "TURBOcharger". If I do LSA I'll document everything.
