lsa
yeah but the reason that cams power starts at 1000 rpm is because its an old flat tappet design with only 447/462 lift, so it needs the low 111 lsa to compensate the loss of upper rpm power that is limited by lift.
No, it is not. The lift has nothing to do with where the power is in the rpm range on this cam, it is not the limiting factor, it is the duration. The reason it has a narrow lsa is to concentrate the power in the target rpm area instead of spread the power across the entire rpm range.
That's kind of what I'm saying, except that I am trying to say they will peak at similar rpm, with different shape powerbands. In these fake graphs, the black lines represent a wide lsa and the red represent a narrow lsa. The first graph long duration cams, the second graph is short duration cams. These pics represent my thinking, tell me if I am wrong.
Just like the cam you posted*4x4)
