Cleaning Head Gaskets off the deck....
If your set on doing it by hand, lots of brake cleaner, scotchbrite pads, and razor blades. Once the bulk is gone, wiping with acetone and using the acetone with the scotchbrite. No easy way around it when you're doing it by hand. The only advantage is you have don't have to worry about as much dust getting into the oil galleys and down in the rings.
Custm2500's Rude Friend
I always do it by hand. Especially on aluminum surfaces. Basically, Razor blades, WD40 and red scotchbrite, brake clean or acetone depending on what I have... I also block off any passages too before starting.
I don't like those 3M Bristle Discs for the dust you mentioned. There also slight on the abrasive side and can disturb the machined finish.
I know there is now a spray on gasket remover that lifts the adhesive but I have not used it yet.
