LS2 conversion?
Just wondering if all the gen 3 performance parts work with the gen 4 ls2 block? Mainly cam and internals? My local machine shop is selling ls2 block for 950 brand new but I am just wondering if you can use a gen 3 forged roating assembly with the block and a gen 3 cam?
from researching, if your using a internals from a Gen3 motor then it should be all plug and play.. u'd only have to relocate the knock sensor fromt he front to the back...
crank has to be a 24X reluctor to work with Gen3 electronics as the Gen4s are 58X reluctor wheel... not too sure why... |
From what I understand, the LS2 (Gen 4) knock sensors are on the sides of the block, and have to be converted to the Gen 3 type. Also, the Gen 4 cam sensor is located on the timing cover, instead at the back/top of the block. There's an aftermarket wiring harness/extension available that connects the cam sensor and knock sensors to Gen 3 wiring.
I believe the 58x reluctor allows more precise ignition and fuel injection timing than the 24x. |
Who makes the harness and what type of valley cover does the ls2 use. Is it like the ls6 or would you still use a pcv valve?
Casper's Electronics make the wiring harness...here's a link: http://www.casperselectronics.com/mm...Category_Code=
From what I understand, an LS2 has the PCV tube on the valley cover similar to an LS6. Pic: http://img508.imageshack.us/img508/8...lockfq8.th.jpg |
thanks that helps alot
| All times are GMT -5. The time now is 07:10 AM. |
