-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Lq9 pistons pressed on lq4 rods? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/lq9-pistons-pressed-lq4-rods-368786/)
CBODYAV Jun 29, 2006 03:30 PM
I already pressed brand new lq9 pistons onto lq4 rods that had 60,000 miles on them. What do you guys think?
RoninsDenali Jun 29, 2006 03:33 PM
Unless the rods are bent or fatigued from abuse... I say you're good to go. I got 83,000m on my LQ4 when disassembled it for kicks while it was out. Rods looked great, and unless you're running heavy amounts of power adders, (Forced Induction, Nitrous) i wouldnt worry one bit.
CBODYAV Jun 29, 2006 04:11 PM
Thanks for your input!
I have another question. I have this engine diassambled down to the block by a buddy of mine and now all the bolts are all over the place. i don't know which bolt goes where? Do you know of any literature that would help me.
1slow01Z71 Jun 29, 2006 05:06 PM
Take pics of the bolts and number them with photoshop and Ill tell you what each one is. Im way too familiar with them:jest:
1SlowHoe Jun 29, 2006 05:50 PM
I dont think you'll have any problems but I am curious as to why you went with LQ4 rods instead of LQ9. The LQ9 rods are a little stronger, which I would assume a little heavier. Was weight of the rotating assembly a concern?
CBODYAV Jun 30, 2006 12:48 PM
Well i figured the rods were fine and i really did not want to spend too much cash on this rebuild. I wanted to make it quick and easy but unfortunetly i have been to busy and i have let the engine get a little rusty. Now i have to take time and carefully clean the block. And i have to round up all these loose bolts.
Elcobugg Nov 15, 2016 08:04 AM
Originally Posted by cbodyav (Post 3382910)
i already pressed brand new lq9 pistons onto lq4 rods that had 60,000 miles on them. What do you guys think?
hey what wrist pin did you use and what was the outcome of the engine?
zachm89 Nov 17, 2016 11:09 AM
This post is from 10+ years ago...:sigh:
1994Vmax Nov 17, 2016 01:47 PM
Yep...... haha. The OP hasn't logged in since 2012 so good luck!
