Lq4 SOMETIMES dies on idle after start, braking etc
#22
What could cause that all of the sudden? I've ran the same tune/set up for 4 years and the problem is new as of a few months ago. After I changed the FPR it seems to have gotten better, as it has only happened a handful of times vs every day, but it still happens.
#23
Have you checked the coil packs?
Could it be vapor locking at some point?
If its random I'm still betting it is a connection error somewhere that randomly loses signal and slowly shuts the motor down.
during the time my temp sensor was half way holding on, when it would lose connection it would choke the motor and kill it fast, also slammed the transmission like it was wanting to lock up and quit rotating.
#24
everything looks good, no misses, good everything. It runs perfect when its good, when its bad, its bad. It never happens on the fly, its always on a restart. i could drive for 4 hours and be fine, stop for gas, start it and it would run bad for that next 4 hours on idle.
#25
So some days you can turn it on and off all day and other "random" days this issue will occur?
both O2 sensors are good, able to log the fuel trims when it does this?
MAF and tb clean, sensors are good?
Fuel pump, filter, injectors?
Sorry for any obvious things to do just trying to brainstorm lol
#26
Well it ran good for a few weeks and then ran like **** again. I swapped the IAC from my other truck and i think its fixed. Wierd thing is that datalogging never showed a problem with the IAC. I've had a problem ever since i put the engine in that it would idle down low sometimes going from D to R or vice versa. This took care of that as well as my stalling. My TB is clean as hell, but when I pulled the IAC it was caked with oil and ****. Must have never taken it out to clean it. All is well now.
SLOPONY
20
Oct 18, 2016 06:05 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
GreyChevy
Jul 7, 2015 08:57 PM
