-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   low oil pressure LQ4 (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/low-oil-pressure-lq4-510355/)
Heavrolet98 Nov 12, 2012 12:10 AM
I just put a LQ4 in my 03 2500HD that had a 5.3 swapped into it before I bought it. I was told.the motor came out of a 03 2500 that was running and driving with no problems with 100k on it. Well I started it up, let it idle for a min or so and shut it down to dowuble xheck theoil level. Oil was fine so I fired it back up and I have low oil pressure coming up on my gauge cluster and the needle on the oil pressure gauge is just barely off 0. When the motor is at 2500rpm theres around 20psi and at 3500rpm its around 40psi. Any ideas? Im thinking about having the oil pump modded to increase the preasure.
greasemykey Nov 12, 2012 12:15 AM
Did you have the pan off for any reason? Sometimes the o-ring for the pick up dries up or cracks and it will give you those symptoms.
Heavrolet98 Nov 12, 2012 07:57 AM
No I never took the pan off.
Heavrolet98 Nov 12, 2012 08:06 AM
I forgot to add that the motor has been sitting for about 4 months if that makes any difference.
greasemykey Nov 12, 2012 10:48 AM
Waist sitting without oil in it? That should not make a difference but I'm curious to know how the oil looked when the engine was taken out.
stock48 Nov 12, 2012 11:27 AM
My guess is Oring like said above.
TXSZ66AVLANCHE Nov 12, 2012 11:36 AM
Looks like you got took for a ride, you can try replacing the pump and pickup tube o ring but doubtful it will help any. Once engine warms up you won't have any oil pressure at all if the need is just above 0 now. The cam, main, and rod bearings probably already have damage to them....probably why the engine was removed and put up for sale.
Heavrolet98 Nov 12, 2012 04:34 PM
Ya the more I read the more I agree the bearings are probably shot already.
Heavrolet98 Nov 12, 2012 04:36 PM
No it had oil in it. The oil didnt look bad at all honestly. No shavingd of any kind that I could see. It looked like it had about 1500 miles or so on it.
greasemykey Nov 12, 2012 04:43 PM
Pull the pan and check. Buy some plasti gauge and see what your gap is.
