-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   low oil pressure 5.3 (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/low-oil-pressure-5-3-a-521204/)
RedRover Aug 20, 2013 11:42 PM
I have a very high mileage 5.3l out of a 2000 gmc swapped in my truck, and i'm only reading 16-18 psi at idle and it never gets above 35-40 even at WOT. My moms van with a 5.3 reads atleast 40 at idle and my buddies lq9 reads 40 too. After my 5.3's ran for 10 min it gets a wicked lifter tick. I'm running castrol gtx high mileage 5w-30. Oil pump giving up? would replacing the pump fix it? Would running thicker oil at least band aid the issue until i have more money to get another short/longblock? next oil change i'm going to sea foam EVERYTHING to see if it's just clogged up with sludge from being 13 years old and having 200k miles.
luisdavid11 Aug 20, 2013 11:51 PM
try a new pump
RedRover Aug 21, 2013 12:08 AM
i would, but it's my DD and i'm the brokest 16 year old ever. "trying" a new pump is a big risk of time and money for me. i would like to atleast be pretty sure it would solve it, and if i would be better off saving up for a new longblock
Ron_Stoppable Aug 21, 2013 12:58 AM
I had the same issue with mine reading 40psi cold @idle then 20psi hot. I switched to a K&N oil filter part# 1017 and used 10w40 castrol GTX. Idles at 50psi cold and goes no less than 40psi hot. If I step on it it shoots to 70-75psi
