-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Low coolant message (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/low-coolant-message-287911/)
graystepside Mar 10, 2005 12:38 AM
Low coolant message
After my truck has been running for about 30 minutes, the low coolant message comes up. The coolant is not low but the light still comes on. Anyone else have this problem?
user 108208932024 Mar 10, 2005 12:49 AM
How do you know it's not low? I would keep filling it till it over flows or the message goes off whichever comes first would be my advice. Mine comes on from time to time but never when it's not low.
graystepside Mar 10, 2005 01:04 AM
Thats exactly what i do. Fill it up, but a while later it is back on.
gametech Mar 10, 2005 04:02 AM
My '99 would lose coolant sometimes and trip the light, but it was really low when it did it. My '02 has never done this. However, my dad has an Impala that has been through 3 bad coolant level sensors. The dealership could never find anything causing them to go bad.
SnakeOiler Mar 10, 2005 05:25 AM
Mine has never come on when it's warmed up, but it has come on when it's cold and I get on it.
01Blackerado Mar 10, 2005 08:19 AM
What kind of coolant are you using!!?? And are you sure its not the T stat not opening up all the way!!??
Zick Mar 10, 2005 11:39 AM
Mine does this every now and then. When it comes on, I just shut off the truck and turn it back on and it goes away. It has only came on like 3 times in the last 6 months. Very random, I'm guessing bad sensor since my coolant is not low either.
KeukaZ71 Mar 10, 2005 07:12 PM
mine used to come on when i park on a slant, like in a ditch. i added more to the reservior, and have not seen the message light since.
Onyx 02 Mar 10, 2005 07:45 PM
Mine has come on a couple times and I fill it up. It hasn't done it since I put the 180 t-stat on last year. Maybe somethings wrong with the factory one ?
jow02327 Mar 10, 2005 07:50 PM
my buddy at the chevy house said it is just a sensor getting clogged up with trash. mine was doing it until they flushed it and it hasn't come back on since
