Loud Ticking
Old Oct 31, 2005 | 07:26 PM
Mvp's Avatar
Mvp
Default Loud Ticking
IM HAVING THIS PROBLEM EVERY MORNING WHEN EVER IM STARTING MY TRUCK WHEN EVER I TURN IT ON THERES LIKE THIS TICKING /SQUEELING NOISE WHENEVER ITS COLD OR ITS RAINING BUT WHENEVER THE ENGINE GET WARM THE TICKING GOES AWAY WHAT DO YA GUYS THINK ITS THE PROBLEM?
I HATE THAT TICKING
Old Oct 31, 2005 | 08:07 PM
FILE's Avatar
http://www.pistonslap.com/
Old Oct 31, 2005 | 08:36 PM
Mvp's Avatar
Mvp
Originally Posted by Tiburon
na i doubt it i know how an engine knock sounds like it kinda like a whisteling noise whenever its cold but if the engine is warm it doesnt do that
Old Oct 31, 2005 | 11:11 PM
FILE's Avatar
It's pretty common on these trucks. My 5.3 doe not do it while my wife's 4.8 does it slightly when it worms up.
Old Nov 1, 2005 | 12:07 PM
Mvp's Avatar
Mvp
yea mine is a 4.8 also do you think thats a 4.8 thing?
Old Nov 1, 2005 | 12:35 PM
Flyer's Avatar
It's prolly valvetrain noise.
Old Nov 1, 2005 | 05:28 PM
FILE's Avatar
Ni.. it's not a 4.8 thing. I have heard it an many other 5.3 and 6.0. The early 6.0's were the wordt thought.
Old Nov 1, 2005 | 05:48 PM
LVSTOGOFST2002's Avatar
my 5.3 taps constantly,it's standard. they should list it on the window sticker as a option.
Old Nov 1, 2005 | 10:10 PM
I listen the sound clip and if your truck makes that kind of noise and it's that loud you are going to have problems down the road. As for the early 6.0 being the worst engine to have piston slap, then I must have an odd ball engine. I have a 99 2500, 6.0L, just clock over 263,000 miles, and it makes no noise at all when I start it up now. However, it did make a little noise in the mornings (went away once the engine got up to operating temperature) a couple months ago, due to lifters leaking down, this was fixed when I replace the stock valve springs (lost spring tension, I could actually fully collapse a few springs with my hands) with a set of LS6 springs.
If this noise started after you got the truck I would look towards a weak valve spring or a lifter. If the noise has been there since mile 1, you might have a piston slap problem, but I would start with the easier problems to fix.
Old Nov 1, 2005 | 10:23 PM
1SlowHoe's Avatar
Destroyer of Transmissions
