Longtubes installed!!
1 Attachment(s)
09 GMC 6.2 Crew Cab, installed Pacesetter longtubes and had a custom y built to fit fully manderel bent with two 3" magnaflow high flow cats, into a 22" magnaflow 3.5" in/out center/center! here are some pics sounds great! will get video up as soon as i change bolts out ended up needing longer ones so theres a rattle since they came loose on the way home..
Nice.
How are you liking it so far? |
like it alot man, it changed the tone its nice! worst part is cruzn bout 70 thats where the drone comes in but thats only in 6th gear.. you run at 3g and quiet as could be haha.. but i think its rubbing on the passenger side, i was foot braking it and it rattles the truck like vibrating and i kno thats what it is so ill have to take it back some time and get it fixed not sure if its the pass side pipe or the driver that comes under the tranny but its deff hitting but only when i get up around 2g to launch! other than that just punching it and stuff it doesnt do it.. but other than that worth the 285 for headers, 150 for cats, and 250 for custom y..
DYNO DAY IS DECEMBER THE 3RD!!! |
heres a small video.. camera doesnt do it justice from in person!
http://www.youtube.com/watch?v=yESIH_Pc-H8 |
Sounds good :thumb: How come your check engine light's on?
*EDIT* Nevermind, I saw in your other thread how you mentioned that you have no rear O2's. You have cats and a custom y-pipe, might as well weld in some bungs and keep an eye on those nice new Magnaflow cat. |
(Post 4583493)
*EDIT* Nevermind, I saw in your other thread how you mentioned that you have no rear O2's. You have cats and a custom y-pipe, might as well weld in some bungs and keep an eye on those nice new Magnaflow cat. thanks man haha.. im pretty proud of it! well problem now is there so far back bc of limited room the id have to buy another set of etensions and have 150 bucks in just extension.. plus i doubt there really gona get hurt that far back anytime soon.. HOPEFULLY!! lol... i do have to go back i was messing around and floored it and heard a thump didnt think anything of it bc it only did it that one time but it had kicked down pretty hard.. well was gona do it from a stop just playing around and you spool it up to bout 1700 and up and theres like a vibrating sound and ill bet you the y pipe is hiting the crossmember just enough to make a difference.. has to be that bc theres deff no tranny problem and it didnt do it before the header and y pipe install.. im gona make a video of it under the truck and just spool it up over the camera to see if i can see where its hitting.. better than sticking my retarted buddy under there while im doing it bc i kno hes gona try to anyway..lol |
Sounds really good.
nice truck
thanks guys! gona do a update and new video with better revs and idle after friday when its tuned!!!
