LM7 to L92 swap
LM7 to L92 swap
I have a 2006 Sierra 4x4 I am thinking about dropping in a L92 out of a 2007 Yukon. I have read several posts and some say it’s pretty well a simple drop in with minimal changes needed, others make it seem like rocket science. I will be leaving my 4L60e in to begin with but would like to know what all it would take to swap in a 6L80e later on. Some posts I read were saying you can use your 5.3 wiring harness and ECM but some were saying otherwise. I would love to hear from someone who has done one of these swaps.
Thanks for the input. I’ll look into the LQ9. Would a LQ9 swap right in and be able to use the wiring harnesses and ECM?
Yes, the LQ9 is the same GEN 3 style engine with the same 24/1x crank trigger. The newer engines are 58/4x.
You could swap the reluctor wheel, change the camshaft and camshaft gear, extend the knock sensor harness and a bunch of other stuff but it's a pain. Using a 6L80e would require the newer E38 computer as well, which none of that would be the same on your truck. None of your gauges or anything could talk with the can-bus E38 computer.
It's calibration and the compression ratio if I recall correctly.
Finding an LQ9 is harder than the standard LQ4 because the LQ4 was used in way more vehicles. A simple cam swap would gain you 30-50hp easy in the LQ4. It wouldn't even have to be anything crazy, a small cam that kept the stock stall converter would give the 6.0 a good power bump.
Lvz2ryd
06-14-2018 12:36 AM
97 Z Me Go
11-22-2009 08:57 PM
xdanny510x
22
07-26-2008 01:27 PM
xdanny510x
01-14-2008 08:41 AM
Ryan23silverado
03-17-2003 05:44 AM
