LM7 with 243 heads
Old Aug 17, 2013 | 11:03 PM
Dont4GetToWipe's Avatar
Default LM7 with 243 heads
I've got to pull my stock 706 heads to get a couple header bolts out that broke on me. My question is should I get my stock heads P&P or buy a set of used 243's?
Old Aug 18, 2013 | 12:41 AM
N20zuki's Avatar
Why not remove the broken header bolts? I removed 3 from my engine when I got it in 20min... Its not hard...
Old Aug 18, 2013 | 07:18 AM
JDC's Avatar
JDC
If you put 243's on you'll also need to have them milled about 0.030 for no loss of compression.
Old Aug 18, 2013 | 02:14 PM
Camin00's Avatar
Probably be cheaper to buy 243's or 799s for $3-400 and have them milled .03 for $100ish than to pay for porting.
If you mill them you will need to check for proper pushrod length.
I have ls7 lifters and milled .03 862s with stock height head gaskets and use a 7.375" pushrod
If you mill the heads I'm 95% sure 7.375" push rod would be your correct length, but every motor is different so check.
Old Aug 18, 2013 | 02:17 PM
Camin00's Avatar
something to think about, 243s will make your 5.3L lose a little bottem end power b/c of the larger runners. probably gain 15-20 at the motor with 243s
this route $600ish
You could fix your head bolts and have the 706's milled to bring your compression close to 10:1 which will give you more bottom and top end power. Probably 10-15 at the motor. this route $200-300ish
You could by a cam with the $300 dollar difference
Old Aug 18, 2013 | 02:42 PM
Well my point is, I have to pull the heads to fix the header bolts. So while they are off I might as well get some work done on them. No sense in pulling them twice. My local shop said they charge $750 for a full port and polish. so I didn't know if it would be cheaper and better for me to just buy some 243's.
Old Aug 18, 2013 | 03:42 PM
Camin00's Avatar
yes it would be cheaper, but you will get more out of Ported 706/862s than you will stock 243s, and keep or raise compression.
Old Aug 18, 2013 | 04:48 PM
Blackpanther99's Avatar
I would at LEAST get them milled if not planning on boosting. If your in the budget, get them ported as well.
Old Aug 19, 2013 | 09:03 PM
I suppose the ideal thing for me to do is to find a set of 243's and have them P&P?
Old Aug 20, 2013 | 10:38 AM
Camin00's Avatar
Is the motor a 6.0 in you sig? the ss?
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
Verz
Aug 21, 2015 06:40 PM
BigEd_72455
Aug 8, 2015 04:49 PM
06 4.8
Jul 15, 2015 07:17 PM
