-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   junkyard lq4 (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/junkyard-lq4-511084/)
bull0109 Nov 29, 2012 11:35 AM
junkyard lq4
Found a lq4 in a junkyard for $300 its a complete block no heads or anything up top it has 150,000 miles is this a good deal? what all should I look for as far a damage wise and what kind of heads should I go with if I do buy this motor?
Atomic Nov 29, 2012 12:40 PM
Not terrible if it comes with the oil pan and covers, stock 317 heads can be found pretty easy.....I would ask if it has been sitting outside, if it has been with no heads theres a good chance the cylinders are pitted.
bull0109 Nov 29, 2012 04:49 PM
If there does happen to be water damage would I be better off just buying a complete motor with high mileage and just tear down clean it up fix what needs to be fix
TXSZ66AVLANCHE Nov 29, 2012 05:41 PM
This block could not be saved, pitting went way beyond max bore.
http://i195.photobucket.com/albums/z...g/IMAG0794.jpg
DR132 Nov 29, 2012 05:45 PM
it really depends on how bad it is. you won't be able to know until you see it and can inspect. it might be able to clean up fine or it may be hopeless, either is just as likely.
TXsilverado Nov 29, 2012 06:57 PM
any before shots of that cylinder?
