Which intake. Bang/buck
Ok so I know the fast lsxt is rly good on our trucks, an the tbss/nnbs r also good for gain/dollar value. But what about the ls6 intakes an all? What would b required to make the swap to tbss or ls6? An which is better an easiest?Can I use my fuel rail? I know I would need bigger injectors an tb but what else? 06 lq9 . Thanks for learin me in advance :hail:
ive yet to read about a proven LSXt on a setup, yeah i seen flow numbers but actual proven track gains on a setup i havent, dollar for dollar? hmm honestly i would go with the new tbss intake, as for the ls6 it would take the f body water pump to beable to use it,the tbss you wouldnt need anything to convert unlike the ls6. anytime you go to a car style intake your have to modify the accessary's. with the new FAST intakes you'll need there injectors and fuel rails. the tbss you can use your own.
Ok, but I would need the dr.x right? I'm going to keep it dbw. Would my tb work? so my injectors will work but don't the tbss ones flow more?
