intake ?
Old Nov 17, 2007 | 09:28 AM
andrew383's Avatar
traveling mod
Default intake ?
would porting a stock truck intake gain anything?or would an aftermarket intake work well with a mostly stock setup?it wont ever have a bigger cam or fi, heads will stay stock as well,but will have headers.how much flow can the heads handle?
Old Nov 17, 2007 | 01:28 PM
closet red neck's Avatar
Someone else will help you with this question. I mean.........uuuhhhhh
James
Old Nov 17, 2007 | 05:41 PM
dirt track racer 81's Avatar
dont even bother messing with a truck intake..the runners are longer than how far the tool will reach to port it...
Old Nov 18, 2007 | 04:50 PM
andrew383's Avatar
traveling mod
do any other truck intakes flow better or worse?
Old Nov 18, 2007 | 05:34 PM
4.8,5.3,6.0 are all the same tb ss and ssr's are different
Old Nov 18, 2007 | 06:05 PM
andrew383's Avatar
traveling mod
different how? like an ls6/ls1 intake
Old Nov 18, 2007 | 09:25 PM
2006 8.1's Avatar
One off a vette, would probably be bigger and larger runners. If you don't go with a bigger TB, it could hurt you. You will loose bottom end and gain a little top RPM power.
Old Nov 18, 2007 | 09:30 PM
Wide Open's Avatar
The stock truck intake seems to work just fine for stock cubic inches up to 6000 rpm so I don't think the trouble or cost would be worth the swap since you aren't changing heads, cam, or going FI.
Old Nov 18, 2007 | 09:59 PM
an ls1 intake included some vettes flows just as bad as a truck intake..bigger tb would add to nothing since the inlet is stil 78mm
Old Nov 18, 2007 | 10:36 PM
andrew383's Avatar
traveling mod
ill just have to do pulleys then
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
