Installing ASP pulley, need help!!
Old Jun 16, 2004 | 07:35 PM
abbo7's Avatar
Default Installing ASP pulley, need help!!
I am installing my ASP pulley, I have it about 80% on and now it is just spinning the crank shaft and I cant make it tighter. Is there any trick that I am missing here?
Old Jun 16, 2004 | 07:56 PM
XLR8NSS's Avatar
Adkoonerstrator
You need to jamb up the flexplate with something to keep the engine from spinning. I've dropped the starter and used a BIG screwdriver going through a hole in the flexplate before. You can also take the little inspection cover off the transmission bellhousing and jamb a big extension or bar up in there to keep the engine from spinning.
Old Jun 16, 2004 | 11:51 PM
abbo7's Avatar
Ok, got it, just installed. Thanks for the help!
thunder550
Oct 8, 2015 04:53 PM
wrb002
Aug 31, 2015 12:00 PM
chevysten
Aug 13, 2015 07:36 PM
bigsapper
Jul 28, 2015 12:56 AM
