Injector dammaged?
Old Apr 18, 2011 | 01:39 PM
PSM's Avatar
PSM
Default Injector dammaged?
I had the gasket between the upper and lower housing for the intercooler go so I have to separate the intercooler this past weekend. When I pulled the fuel rail and injectors I noticed on one of the injectors, the hard plastic/rubber tapered section just below the lower o-ring on the nose had a gouge in it. The o-rings all looked looked fine though. Should I be concerned about this (is that a sealing surface or is the oring what seals the injector) or can I try to work it over and put it back in. I didn’t start pulling to see if I could pull that tapered section off. I’m thinking of putting it back in one of the front holes so If I have to replace it I can.
Old Apr 18, 2011 | 06:40 PM
swift700's Avatar
Can you show a picture of the damage?
Old Apr 19, 2011 | 09:29 PM
PSM's Avatar
PSM
Here's a couple pics of the injector
Old Apr 19, 2011 | 09:54 PM
swift700's Avatar
If the body of the injector is not cracked through to the center then I'd say it's good to go. As long as fuel won't leak sideways through that crack there should be no issue.
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
