How much transmission fluid does your truck burn?
Old May 28, 2005 | 07:02 PM
NovaTime's Avatar
Default How much transmission fluid does your truck burn?
I've had the truck for 5,500 miles, and I was a little low when I checked today. I checked last month and it was fine...any one have any ideas why it would burn fluid?
Old May 28, 2005 | 09:06 PM
KySilverado's Avatar
Can't burn it. Has to leak it. With the old vacuum modulated units was possible to suck it into the engine if the modulator went bad and burn it in the engine. I've not ever added any.
Old May 28, 2005 | 09:30 PM
NovaTime's Avatar
I know very little about transmissions. I haven't noticed any fluid on the ground where i park, and the lines looked okay.
Old May 29, 2005 | 12:04 AM
Might not be the lines. could be the pan gasket, if some one has changed it and used a cork gasket it could leak. You have to be carefull with those gaskets. IMO. But could be other places as well. (front seal, tranny cooler,ex) Just have to check it out. Did you check it when it was hot?
Old May 29, 2005 | 12:29 AM
NovaTime's Avatar
The engine was reasonably warm. The truck ONLY has 5,500 miles total, so I know the gaskets haven't been changed. It's weird, thats for sure.
Old May 29, 2005 | 12:31 AM
1SlowHoe's Avatar
Destroyer of Transmissions
It's under warranty right? Make the stealership check it out. Then if you have tranny trouble later you can show you brought it in and they didn't fix it.
Old May 29, 2005 | 12:44 AM
Couldnt have said it better.
Old May 29, 2005 | 12:56 AM
NovaTime's Avatar
Now that is a plan.
Old May 29, 2005 | 08:27 AM
Now that is a plan.
Just a little incline will make it check wrong. Good level surface when checking it?
Old May 29, 2005 | 09:10 AM
smokeydoge's Avatar
And hot and cold....
Also check the rear seal.
