-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   How much of a gain? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/how-much-gain-492057/)
SunsetOrange01 Nov 14, 2011 07:24 PM
How much of a gain?
Planning on getting some stuff for next year, just curious on what kind of gains i could expect, 1/4 mile wise and hp wise?
I have a 01 RCSB w/5.3
Have a cold air intake already.
Tune prob a Nelsons
Long tubes
Off road y pipe
Decent exhaust system
80mm BBK Throttle body
E Fans
3.73 gears
MSD Coils
MSD Plugs
leveling the back
stock 18" wheels
Things i may do but not set on doing it yet, small shot of nitrous 50-75 at the most and maybe a cam.
Nuclear Endless Nov 14, 2011 08:08 PM
well with the tune, longtubes, fans... I say you pick up maybe 30-45hp, maybe drop a second on your slip if you're lucky and are slow enough to begin with :jest:
Not sure what you run now or what gears you were running before, so hard to say how different it will feel.
Cam and nitrous would be exciting though :nod:
Out of all those mods... a Nelson tune would most likely be your favorite, makes the truck a lot more fun to drive :)
bmd_CL Nov 14, 2011 09:15 PM
dont our trucks run a mid 15 or so stock? i ran a 14.4 with full exhaust, cai, tune, efans, and a posi...and the tune needs some work so im sure it would be good
mhotrodscooter Nov 14, 2011 09:44 PM
Tune prob a Nelsons
Long tubes
Off road y pipe
3.73 gears
cam it & have some fun..
SunsetOrange01 Nov 15, 2011 07:49 AM
Never taken it to the track, and its basically all stock beside the cai.
slow.8 Nov 15, 2011 08:17 AM
i wouldnt waste money on the MSD coils,
snowbunny2 Nov 15, 2011 10:05 AM
^ what he said about the coils. Your stock ones are plenty strong enough. Spend the money elsewhere.
youngbuck Nov 15, 2011 12:01 PM
I wouldn't worry with the bbk.
dmelvin Nov 15, 2011 12:49 PM
Both of these are true. Our stock coils are pleanty strong, plugs are iffy depending on mileage, and if you're going to start spraying you may need to just change plugs again. Use the money you were going to spend on coils and the throttle body and buy yourself a cam.
kr1s Nov 15, 2011 01:37 PM
x's 2
The tune is a huge difference, and yeah it makes the truck a whole lot funner to drive!
