4.8 to 6.0 LQ9 swap worth the hassle?
Old 06-09-2019, 06:43 PM
WhiteRCSB's Avatar
Post 4.8 to 6.0 LQ9 swap worth the hassle?
Hello all,
I currently have a 4.8 in my 2000 RCSB. It has the texas speed 216/220 .550 .550 cam, Long tubes, and a yank 3000 stall (truck made 310hp 280tq)
I would like the truck to be a bit quicker and have more low end. I really do not want to mess with forced induction so here is my plan.
get an LQ9
228/230 .600 .600 cam
and the use my existing stall and long tubes.
my question to you all is, will this swap be worth it? or will it not act much different than my current setup? thanks
Old 06-09-2019, 08:12 PM
FFDP's Avatar
A night and day difference is what it will make.
Think about the torque. The stock 6.0 already makes more torque that what your current engine is even putting down. Add a camshaft and you will probably be over 100ft/lbs more torque and another 60-80hp at least over the current setup.
That will be like slapping a small blower setup on the 4.8 but for less than half the cost.
Old 06-10-2019, 06:09 AM
13 Second Truck Club
trxmxzx's Avatar
I just came from a SC 5.3 to a N/A Lq9/243 head and it’s very very impressive- I wish I did it years ago. Plenty of low end grunt
Old 06-10-2019, 10:09 AM
firebladeJJ's Avatar
I just did the swap, 4.8/t56 to a 6.0/t56. It is absolutely worth it, I did a stock rebuild with a mild cam, its damn quick plus my gas mileage hasnt changed much, once the newness of the acceleration is some what gone I suspect i'll get better mileage than before. No more upshifts just to climb a hill with the AC on, it pulls hills so much easier now.
Old 06-10-2019, 11:22 AM
arthursc2's Avatar
Received 1,433 Likes on 1,061 Posts
there wont be much hassle, IMO. And its certainly worth it. I am looking at a 6.0 myself for a truck I plan to build for road trips
Old 06-10-2019, 12:35 PM
TXsilverado's Avatar
stock 5.3 to stock 5.7 dropped my et 6/10 in the 1/4. 4.8 to 6.0 is a major upgrade.
Old 06-10-2019, 02:05 PM
Vortec350ss's Avatar
yup its huge... the 4.8 is very gutless down low.
Old 06-10-2019, 09:21 PM
WhiteRCSB's Avatar
What all was done to your 5.3?
what cam is in your lq9
do you have dyno numbers for both?
Old 06-11-2019, 06:50 AM
trxmxzx's Avatar
04- 5.3 862 heads milled .032” TR220-112 (220/220-.551/.551-112lsa) pacesetter long tubes w/ORY pipe, Efans, 3000 stall 3.42 gears 30.4” tire on 20’s - MP 122HH 8-9psi 3rd gear pull converter locked- 417whp/402ftlb
no numbers yet on the new setup- but its faster hope to get to the track soon
lq9/243/ls9 headgaskets- 10.6:1 comp. BTR STAGE 3 truck cam -42lb injectors
NicD
27
03-27-2010 02:43 PM
laynlow77
04-22-2008 04:13 PM
2002C5COUPE
33
02-21-2007 05:58 PM
JimS
02-15-2006 07:20 PM
LS1S10
09-20-2004 11:48 PM
Quick Reply: 4.8 to 6.0 LQ9 swap worth the hassle?
