help, spun cam bearings, or spun main bearings
Just finished up a little while ago with KBs motor swap. Had a little trouble getting oil pressure, but after it was fired up, instant pressure, 40+
now the question, it knocked a little, (no tapping, or clacking, just a hint of hitting an extension on the side) and went away after the second 15 min cycle. I started it up, ran it for 5 minutes, and held it at 1,000. Waited 10 or so something minutes, 4 radio songs later. Cranked it again, and a whining sound started. It would only come on at low RPMs. Once it was off idle, it went away.
Now on the third start, it's pretty obvious, and doesn't go away until 2K or so. It sounds like a roots style blower, . . .noticeable or loud at idle, and gets more faint as you rev it.
KB and I both could not remember if we tightened the cam plate, but we're sure that he did the cam bolts right. Any ideas? We took a vid.
Full ARP bottom end, stock bottom end block with 14K something miles on it.
5 year bitches!
why did you rev the motor for 10minutes?
if the bolts on the bottomend werent tightned properly you could have issues
if your hearing sounds, check the dipstick for shavings also for reasurance drain the oil and cut out open the filter to see if you have shavings. if you have shavings time to rebuild that motor
13 Second Truck Club
Thanks for the reply, I do know for sure the cam bolts were torqued down correctly...but I honestly don't remember the cam plate. I sure hope that's the problem. I'm trying to get the video uploaded, but I've gotta find a firewire card..
I checked the oil stick and nothing but oil. It sounds more like a pissed off squirrel at a feeder. It's very low pitched, with no screeching. Anything past 1,600 - 2K, and the noise it gone
If the cam plate is loose your oil pressure would be low since it seals the cam oil channels.
Cut the filter apart on the sides just under o ring and check the filter element for material.
I listened to it this morning (they're doing the work in my garage). I would describe the sound as a chirping sound. No grinding, tapping or knocking.
I've never heard a spun bearing before, but I guess that it could be that. Can anyone describe what a spun bearing sounds like?
