Help me pick heads 243 best bang for buck
Old Nov 23, 2011 | 10:04 PM
evand's Avatar
Default Help me pick heads 243 best bang for buck
I want a pair of heads for my stock lq9. I added a fast intake. I am undecided on cam at this point and I am going to a 408 eventually. Best for N/A
Which 243 would you get. I want the best bang for the buck.
Old Nov 24, 2011 | 06:02 AM
mhotrodscooter's Avatar
If you wanna go cheap,go 243's. When you decide to go 408 send them off for porting.
Old Nov 24, 2011 | 07:38 AM
Brand new GTO 243's are 319.00 a piece from SDPC.
Old Nov 24, 2011 | 07:44 AM
old motorhead's Avatar
If you're going to build a motor anyway, the best bang for the buck is ported 317's. Same flow capabilities as ported 243's, just bigger combustion chambers. You can dial in your compression ratio with the pistons you choose on your build. No need to pay a premium for small chamber 243's. You already own a set of 317's that you're familiar with. 243's will cost you +-$400 and it's a bit of a crap shoot finding a good used set.
Old Nov 24, 2011 | 09:42 AM
evand's Avatar
I guess Frugal would be better than cheap. I don't need a set of super high end heads. Maybe 2 grand or less would be a good budget. I was looking at AI or TEA reworked heads. I am not going super high lift I am going to try and use GM performance springs. TEA mid flow numbers look huge
Old Nov 24, 2011 | 10:14 AM
Stock for stock the 243's will out flow 317's. 243's have the best Combustion chamber design.
Old Nov 24, 2011 | 11:22 AM
zero2sixT's Avatar
I say wait until tax season. Good deals come out of the wood work. Ive seen a few nice sets of afr's go for less that $2k. One set went for $1400!
I personally wouldn't swap a stock set of heads for a stock set of heads. 243 flow numbers are a little better than 317s. The real advantage of swapping is the compression bump.
Old Nov 24, 2011 | 01:08 PM
evand's Avatar
I want a bump in compression and a better flow
Old Nov 24, 2011 | 01:56 PM
364HC's Avatar
Banned
Spdc has the 243's p&p woth springs and valves for$499.99 each. Cant beat that price
Old Nov 24, 2011 | 02:07 PM
evand's Avatar
Scoggin Dickey Parts Center X88958765 - LS2 CNC Aluminum Cylinder Heads, w/ 65cc Chamber | SDParts - 1-800-456-0211 these??
