Header issue after install - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 06-14-2018, 08:39 AM   #1
Registered User
Default Header issue after install
i put on a set of speed engineering headers this weekend, i am losing oil now and keep burning oil right and getting a burning smell from the passenger side, anybody have these issues after header install??
cooperthetrooper is online now   Reply With Quote
Old 06-14-2018, 09:25 AM   #2
terravast4's Avatar
is your dipstick tube seated properly?
terravast4 is offline   Reply With Quote
Old 06-14-2018, 09:26 AM   #3
Check to make sure you seated your oil dipstick tube all the way seeing it's on the passenger side id look there first
Tdemontigny91406 is offline   Reply With Quote
Old 06-14-2018, 10:32 AM   #4
Registered User
it looks like it is im going to pull it back off tonight and check that first
Old 06-14-2018, 02:25 PM   #5
BlackPanther6.0's Avatar
Happened to me too, make sure dip stick tube is in all the way in block, oil sprayed my nice new headers wasnt too happy about that
Live and learn
BlackPanther6.0 is offline   Reply With Quote
Old 06-14-2018, 08:47 PM   #6
Registered User
Old 06-14-2018, 08:47 PM   #7
Registered User
Not the dipstick I can't keep this boot from touching the header
Old 06-14-2018, 08:52 PM   #8
I reccomend the MSD wires, you can bend the boots to clear away from the header, or just twist the wire at the top on the coil side enough to where it will start to make the boot bend away from the header
Old 06-14-2018, 08:59 PM   #9
Registered User
Ok well that wasn't it either I'm sure that was part of it I'm stumped guys anything else you can think of
Old 06-14-2018, 09:03 PM   #10
Quote:
Man if it's not the dipstick tube then idk what it could be to be honest. Unless you developed a valve cover gasket leak, its gotta be the dipstick if its oil
Thread Thread Starter Forum Replies Last Post
Header install with header studs - any issues? zblee GM Engine & Exhaust Performance 17 11-03-2015 08:11 PM
Fuel Pressure Issue after Racetronix Install MikeD. FUEL SYSTEMS 6 10-27-2014 10:01 AM
Got a few codes after header install!!! inmywhitez GM Engine & Exhaust Performance 7 07-20-2006 07:49 PM
running rich after header install LesPaul GM Engine & Exhaust Performance 8 06-17-2006 11:30 AM
truck running horrible(rich?) after ASM header install VTODD GM Engine & Exhaust Performance 30 04-30-2005 05:34 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
