Head/Cam help....5.3l
Old Jun 14, 2008 | 09:13 AM
  #41
cavmattz24's Avatar
Oh yeah, this truck will also eventually be seeing a 150-200 dry shot.
Old Jun 14, 2008 | 09:47 AM
  #42
cmb570's Avatar
Originally Posted by cavmattz24
I will likely be touching 7000+ rpm from time to time (due to cam size) and anywhere near 7000rpm's I don't trust stock lifters to hold up. While I have the heads off I may as well throw in some Morels...better to do it now than regret not doing it later.
I'm using the LS6 intake because of where I believe this cam is going to produce power.... up top. I like torque too... but dont need much in such a little truck that wont be used for towing.
Thank you! Neither can I!!
I look forward to seeing the numbers you put down with those heads.. the look great! Good luck.
Do u have to change the accessory drive stuff up front when u change the intake ?
Old Jun 14, 2008 | 10:04 AM
  #43
cavmattz24's Avatar
Yeah
There are guys that have done an LSx swap in their S-10's that have kept the truck accessories. I chose to go with the corvette accessories just for the extra space for the radiator and e-fans!
You can use an LS1/LS6 manifold on the truck without changing accessories but you have to relocate your idler pulley and cut part of your alternator bracket. That's what I remember about it at least.
chevy1224
Jul 13, 2015 07:50 AM
Chiphead
Feb 12, 2014 10:06 PM
MAY-DAY MAY-DAY
Sep 25, 2013 11:18 PM
Rook
11
Jul 4, 2005 05:08 PM
