-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Which head bolts? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/head-bolts-474948/)
MDI2500HD Jan 3, 2011 06:02 PM
Which head bolts?
What should I use for head bolts? I have almost all my parts for my project, going with 243 heads, Thunder Racing cheater cam, TBSS intake and a 90mm TB. This is all going on an 02 2500HD.
andrew383 Jan 3, 2011 06:19 PM
ARP's IMO
TIM Z Jan 3, 2011 07:16 PM
I would call and get them from SDPC, they helped me get the correct set for my 6.0. Great knowlegeble guys there for sure.
aaronmc Jan 4, 2011 10:07 PM
Originally Posted by andrew383 (Post 4609319)
ARP's IMO
x2
I went with studs.
OnyxSilveradoSS Jan 5, 2011 12:32 PM
the GM parts counter will have studs too, there is a post about what they are from.
Mangled03gmc Jan 5, 2011 01:35 PM
Arp's for sure, get the reusable ones. You want the ones that are different length.. Ones in 05 up went to 2 all the same size
Edit--- Wrong info at first ;)
moes04silverado Jan 5, 2011 02:29 PM
another vote for ARP - studs!
TXsilverado Jan 5, 2011 02:35 PM
Originally Posted by Mangled03gmc (Post 4610701)
Arp's for sure, get the reusable ones. You want the ones that are all the same length IIRC.. Ones in 05 up went to 2 diff size's
please explain...i have a 05+ LQ9 and havent heard anything about redesigned head bolts. does each head use a different length bolt?
Mangled03gmc Jan 5, 2011 03:03 PM
When I ordered mine, they told me there were 2 diff part numbers, that I needed the ones with the shorter bolts..
1997-2003 10 long and 5 short
2004 + all 15 bolts are short
KLUG'S SS Jan 5, 2011 03:36 PM
I found this out some time ago the hard way, spent some $ on a good set of head bolts for my 03 well because of a little mishap:eyes:I now have an 04 engine in my truck so I am putting the heads back on and I am saying to myself wait a minute these bolts don't look right. This was right around that time where their wasn't much info at all out their yet on it so I had to make some phone calls and see what was going on.
