got the cam spec'ed from Pat G , need your help
Old Oct 2, 2011 | 05:35 AM
iamkeniff's Avatar
Do not put stock head bolts, its not worth the time of standing in the engine bay to pull the bolts to the degree needed 2 different times. I did 1 set of stock bolts and i will NEVER do them again.
Thats a big cam for a "dune" 4wd
Old Oct 2, 2011 | 02:12 PM
iamkeniff's Avatar
Originally Posted by 06Sierra2
if you deck the heads then you cannot use 7.4 pushrods as they are for stock gaskets and stock heads. with a thinner head gasket or milled heads you need shorter pushrods
Think this will prove that his truck with stock heads and LS7 lifters require a 7.425" pushrod
Old Oct 2, 2011 | 11:27 PM
sand man's Avatar
Pat specd me the pushrods and springs and recomended a lifter change lol
7.425" with stock heads stock gasket and TEA dual gold springs .660" or PAC 1518 .650"
what to buy?
Old Oct 3, 2011 | 12:07 AM
iamkeniff's Avatar
Yeah a lifter change is needed from a DOD lifter, the DOD lifter is longer than a normal LS7 lifter.
The cam should do well, plans of a converter swap in the future?
What are the TEA dual spring price vs the PAC?
Old Oct 3, 2011 | 06:06 AM
sand man's Avatar
i was kidding when i said " recomended" i now they are bad from the factory with the stock cam
yeah a 3000-3200 triple disk
yeah i searched the TEA site and didnt find a dual gold 660 are the patriot dual gold good?
thanx niff
Old Oct 3, 2011 | 06:53 AM
iamkeniff's Avatar
I run the partiot extremes on my 6.2 and love them. Many many 6800 rpm pulls
Old Oct 3, 2011 | 07:20 AM
sand man's Avatar
is this the part number?
8501
Old Oct 3, 2011 | 08:13 AM
iamkeniff's Avatar
I would think bc the 8401 is the .650 lift
Old Oct 3, 2011 | 03:36 PM
sand man's Avatar
sent some messges to a vendor lets see what he has to offer
Old Oct 3, 2011 | 04:26 PM
sand man's Avatar
sent some messages to some vendors to see how much itll sum up too and see i can make a good deal with every thing on my list
parts requsted
custom cam 3 bolt
pushrods
lifters
lifter trays
oil pump
ARP head and cam bolts
LS2 vally cover
LS2 timingchain and gear
springs
ill try to find the best deals on the gm parts as for the rest ill take from the vendor
