Going with z06 cam,got some questions...
OK IM IN TE PROCESS OF PURCHASINGA 02-04 LS6 CAM FOR MY 08'BLOWN 4.8,GOT A COUPLE OF Q'S THOUGH.
1,AM I GOING TO NEED PUSHRODS?IF SO WHAT SIZE?
2.WHAT ABOUT SPRINGS?
3.WHAT NUMBERS AM I LOOKING AT IN HORSEPOWER DIFFERENCE?
4.WILL THIS SWAP AFFECT BOOST?
5.AM I GOING TO NEED THE LS7 CAM SPROCKET SINCE IT BEING A NNBS?I HEARD GUYS CHANGING THAT FOR SOME REASON?
HERE THE SPECS
http://paceperformance.com/index.asp...D&ProdID=73063
I APPRECIATE THE REPLY'S GUYS -THANKS
HERE THE SPECS
1. yes, not sure, Z06 cam has differnent base circle so you need different size pushrods i think
2. yes, yellow Z06 springs at least
5. yes, it has the cam sensor in it and will bolt to the old style camshafts.
HERE THE SPECS
HERE THE SPECS
1,AM I GOING TO NEED PUSHRODS?IF SO WHAT SIZE? 7.4"hardened
2.WHAT ABOUT SPRINGS? ls6 yellow springs
3.WHAT NUMBERS AM I LOOKING AT IN HORSEPOWER DIFFERENCE? bout 30hp or so
4.WILL THIS SWAP AFFECT BOOST? it may a little on the good side idk
5.AM I GOING TO NEED THE LS7 CAM SPROCKET SINCE IT BEING A NNBS?I HEARD GUYS CHANGING THAT FOR SOME REASON? not sure...maybe??
HERE THE SPECS
HERE THE SPECS
that should be about right
If your buying pushrods then get the 7.425's, but stock push rods will work fine with that cam. I think, don't quote me on this, but some of the new motors use only 1 bolt to hold on the cam gear on, so you would need the ls7 sprocket for it 3 bolt pattern and front cam sensor. It is a VERY good boost cam.
