gen-3 hotcam
I drove a 98 Camaro Z28 with one (LS1 Hot Cam Kit), it was a huge improvement. I'm not sure if its the same for the trucks. It ran a 12.7 with just the cam in the car.
Originally Posted by hink9
has antone ran one of these hot cams for ls-1's yet? Duration .050 Int. 219 Deg, EXH 228 Deg.
Lift Int .525" Exh .525"
Lobe Centerline 112 Deg
i wouldnt suggest it at all, esp with the needed tq down low and idle stability for heavy trucks. they idle poorly (good and bad) but were NOT designed for the ls1. other cams are better for drivability and will make as much if not more power. if you want a mean idle with a programing nightmare, the hotcam is for your and your 5.3 auto combo.
12thstreetjunkman
Dec 10, 2007 06:21 AM
Torque_Wrench
18
Mar 25, 2007 11:37 AM
dubrado
Apr 15, 2004 07:33 PM
Okie02
11
May 21, 2003 10:25 PM
