-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   flex fuel injectors? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/flex-fuel-injectors-437687/)
teamblackandred Mar 23, 2009 09:04 PM
just wondering how many pounds per hour that they can be maxed out at in an 06 silverado with a 5.3 have been looking at doing a cam and head swap and just trying to get things in order .thank you
alanderson1978 Mar 23, 2009 09:10 PM
I don't know, but if you are going to change them, you may as well get 42# injectors. You can get a used set in the classifieds for $200-250
teamblackandred Mar 23, 2009 09:21 PM
are they the same as the return style injectors?
03tahoe22 Mar 23, 2009 10:02 PM
I was told my Magnacharger that my 03 Flexfuel injectors were 38# and could have ran them with supercharger, bc that is actually how they sell the flexfuel kit w/o injectors. Bought a used Radix that already came with 42# so I never tested it.
Phantom Mar 23, 2009 10:08 PM
Efi live says mine are 35#. I never seen more than 50% duty cycle on mine
Phantom Mar 23, 2009 10:09 PM
What I want to know is what kind of injector are they? Regular truck injectror? Ls2? What are they?
lucky77 Mar 24, 2009 12:06 AM
i think there rated at 32lbs . they have 4 holes/
rst06rado Mar 24, 2009 11:14 AM
Hey guys. He is actually asking about my truck. I bought a set of injectors just in case I needed them, and If I don't I'm going to sell to "teamblackandred". How many pounds are my stock injectors good for? I have a 2006 RCSB Regency 5.3 2wd. It started its life off as a w/t from the factory. Thanks.
rst06rado Mar 25, 2009 08:41 AM
Somebody must know the answer.. Are all 05+ 5.3 trucks flex fuel?
Phantom Mar 25, 2009 10:07 AM
No they are not. The easiest way to tell is to have the computer read. If the injectors are like 33lb or whatever. Or if the gas cap is yellow. And my truck has alumin fuel rails as well
