Finally installed a catch can
yep there is a part number here for a ford pcv that supposed to work, but since it has been running like this for a year with no noticeable problems i was going to see if it infact got oil in the can first!
I learned changing too many things at once could cause problems that are hard to find!
You can run the driver side valve cover to catch can then check valve then to the top of the intake.
For the passenger side i have the valve cover running to a catch can then to the filter on my turbo so its always under vacuum.
Corvette454l88
Sep 1, 2016 01:24 AM
