Factory installed a 4.8l instead of 5.3l?
it's not as big of a difference IMO as the modular fords...the 4.8's really only lag behind off the line, once they're moving they'll stay pretty close to a stock 5.3.
As for a 4.8 making it in place of a 5.3, from the factory. I suppose it 'could' happen, but is so unlikely that I'd have to personally witness it to believe it. You sure its a 4.8L? You measure the bore/stroke? Any of the bolts in the engine compartment look like they've been removed, as if the engine were replaced?
Original owner has all the dealer service records from new all the way up to a month or so ago. He had all service and maint. done at the same dealer from new. All the dealer records show 5.3l along with the original window sticker and the vin all say 5.3l.
The drive train was 100% stock I am 99.9% sure on that. If they did swap the motor they were pretty good, i didn't see any marks on any bolts ect...that you would normally see. All the wiring ect. was untouched everything was in its place even had all the factory labels on everything. The tune was for a 5.3 on the stock ecm. The motor has flat top pistons and had a stock factory 99 cam, unless they accidentally put flat tops in a 5.3l in 99 it has to be a 4.8l.
Not sure who told you that, but that never happened.
Not really, I drove a bunch of them before I bought my truck and the difference is very minor. Now with same mods, a similar 5.3 truck you can really feel the extra tq. Sub'd for outcome. Of course when your talking about the 99 models, the 4.8s were way down on power compared to the 5.3s.
lxcoupe
Jul 27, 2015 08:19 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
