nightmarechevy |
06-20-2005 08:39 PM |
You can run the off road y pipe and have a section cut out and have a cat welded in. If you want to run true duals you can run a pipe back from each header into the the mufflers, but I would recommend an x-pipe to equal out the backpressure on each side. You can do the same with cats on this setup, just cut out a section and weld one in. The stock cat y-pipe is basically useless after installing the Pacesetters so if you want to run cats you will have to get one welded in somewhere.
