-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Enter to Win Contest! (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/enter-win-contest-453578/)
MikeGyver Dec 14, 2009 09:52 PM
My oil pressure dropped from 40-60 psi to 20-40 psi. I changed the oil and found what looks like anti-seize compound on the magnet, and silver and copper-like flakes in the oil. We all know what the flakes are, and my old timer mechanic buddy says the stuff on the magnet is iron. He said steel would be black. We are guessing that a main bearing stuck to the crank, and the metal on the magnet is the bearing bore in the block. Or, a cam bearing stuck to the cam and wore the cam bore away. I cut open the filter and took pictures, I wish I saved some of the magnetic stuff.
Anyway, whoever guesses from the pictures what bearing it is wins the prize, to be announced later.
http://i36.photobucket.com/albums/e1...h_IMG_0122.jpg
http://i36.photobucket.com/albums/e1...h_IMG_0123.jpg
http://i36.photobucket.com/albums/e1...h_IMG_0117.jpg
http://i36.photobucket.com/albums/e1...h_IMG_0118.jpg
http://i36.photobucket.com/albums/e1...h_IMG_0120.jpg
http://i36.photobucket.com/albums/e1...h_IMG_0121.jpg
Z'06 Dec 14, 2009 10:01 PM
Rocker bearing?
silveradokidd_4518 Dec 14, 2009 10:03 PM
any noises?
if the pressure dropped like that im gussing cam bearing..
charcoal03silvy Dec 14, 2009 10:04 PM
The kind that makes the engine work right??
texasbullseye89 Dec 14, 2009 10:05 PM
an important one. whats my prize?
CHEVRACER83 Dec 14, 2009 10:25 PM
im guessing the 4th main bearing
03chevyroyce Dec 14, 2009 10:27 PM
kanuter valve bearing?
looks like a cam bearing to me
MikeGyver Dec 14, 2009 10:31 PM
Originally Posted by Z'06 (Post 4353359)
Rocker bearing?
Good answer.
Originally Posted by silveradokidd_4518 (Post 4353362)
any noises?
For a long time it has had a weird tick,tick,tick.........tick,tick,tick.........tick ,tick,tick, at around 1600 rpm, but nothing new after the oil pressure loss. I think cam bearing would probably be the best case, because it seems like that would be the engine builder's fault, wouldn't it?
So far, you two are tied for best answer.
redsilverado05 Dec 14, 2009 10:34 PM
I'm guessing the crank shaft is knocking against something ever so gently.
03chevyroyce Dec 14, 2009 10:37 PM
muffler bearing? the kind that requires a left handed screw driver right?
