EATON POSITRAC
WHEN PURCHASING ONE OF THESE BAD BOYS WHAT ALL DO I NEED TO GET. IS THIS ALL IM NEEDING.ALL I WANT TO DO IS CHANGE OUT MY LIMITED SLIP FOR A POSITRAC REAREND.
WHAT IS THE PART NUMBER FOR THIS POSI. I HAVE A 10 BOLT 30 SPLINE REAREND. IS THERE EXTRA PARTS THAT ARE NOT INCLUDED I GUESS IS WHAT IM TRYING TO ASK.OR IS IT ALL IN ONE PACKAGE. BUY AND INSTALL AND GO. THANKS :cheers: |
Re: EATON POSITRAC
Just get an 8.5, 10 bolt, 30 spline and an instalation kit. The installation kit is less than $100
http://www.tomsdifferentials.com/cat43.htm http://www.gearsareus.com/_private/G...f/bearings.htm |
Re: EATON POSITRAC
IS THIS PART NUMBER 8.5EP30 FOR ALL EATONS OR IS THAT JUST THAT WEB SITE?
Re: EATON POSITRAC
let me go to the storage room and see if I still have my box for mine.
Re: EATON POSITRAC
ok its part #ED 19559
hope it helps. |
Re: EATON POSITRAC
:confused: Limited slip is the same thing as posi
Re: EATON POSITRAC
JUST TO MAKE SURE. THATS FOR AN 8.5,.6 30 SPLINE 10 BOLT REAREND RIGHT. IM GONNA ORDER ONE TOMORROW.JUST WHAT TO MAKE SURE I WALK IN WITH THE RIGHT PART#.
THANKS |
Re: EATON POSITRAC
I THOUGHT POSI TRAC MAKES BOTH WHEELS SPIN INSTEAD OF JUST ONE. THATS THE WAY I WAS EXPLAINED. CORRECT ME IF IM WRONG BECAUSE I DEFF, DONT WANT TO GET THE SAME THING A ALLREADY HAVE
Re: EATON POSITRAC
JUST TO MAKE SURE. THATS FOR AN 8.5,.6 30 SPLINE 10 BOLT REAREND RIGHT. IM GONNA ORDER ONE TOMORROW.JUST WHAT TO MAKE SURE I WALK IN WITH THE RIGHT PART#. THANKS |
Re: EATON POSITRAC
:confused: Limited slip is the same thing as posi |
