Drag Radial?
I am going to get some drag radials and put them on my stock 16" wheels. What is the widest tire I can put on the stockers? Also, which is better, BFG's or Nitto's? What is the best tire pressure for them when at the track and how long do you need to heat them up? Thanks.
Kent |
Re: Drag Radial?
I wouldnt go any higher than a 285.
Daren |
Re: Drag Radial?
Hey Daren, you still got those tires for sale? Also, what size do you recommend for the track? I have the 4 16x7 stock wheels in the garage and I want to get a good track setup with them. What do you suggest for the front and back tires? My 17x8's are pretty heavy. Do you think I should run at the track with the 16x7's up front or should I keep the 17x8's? Thanks for any help.
Jerod |
