Does this engine need to go to the machine shop?
Old Jun 19, 2010 | 05:04 PM
Atomic's Avatar
I have a gauge for that
Originally Posted by EVILGMC
richard.....what did i ******* tell you!!!!!!!!!!!!!!!!!!!!
hahahahahahahaha
Dont get snappy, bitch
Let me reiterate this isnt my engine, its a friends who he bought from a salvage yard. He is trying to save as much money as possible and doesnt need or want anything more than a stock 6.0 with maybe a cam. Buying new pistons is not in the budget.
Old Jun 19, 2010 | 05:30 PM
1LOW4X4's Avatar
Banned
Ok then. Still have them mic it. If its beyond stock clearances from the get-go, you have no choice. If its a few thousandths out of less, hone it. Either way, hone it and ring it.
Old Jun 19, 2010 | 07:21 PM
Jordan927's Avatar
Not to say anything bad about your friend....but I hear this story all the time. I don't have the money for a full rebuild...so I'm just gonna... STOP HERE
If you don't have the cash for a rebuild...save up for it or buy the parts little by little....Half *** build means a half *** engine....and it will be as good as the money and work put into it....and you will just spend more sooner to do the job again.
He likely will not need pistons or rods...if its in spec...But if not pistons have to be ordered...just putting in oversize rings on stock pistons is just cutting corners. So what if you have to wait a month or two longer...or pick up an overtime shift or two to pay for it...Hell I stopped eating, drinking, smoking...anything to scrape up an extra few bucks to drop into my builds in the past.
I do like the idea of buying oversize rings and filing them to fit though...Never thought about doing that...that would make a nice fit for sure.
Old Jun 19, 2010 | 07:31 PM
Atomic's Avatar
I know exactly what you mean, and I emphasis to him that it is much cheaper to do what needs to be done the first time instead of later when it takes stuff with it. The oversized rings is a good though, I havent thought of that. The cheapest 4.030 pistons I could find were around $700. The stock pistons look fine and perfectly reusable.
I think he just may be getting discouraged because he bought this engine with the perception it was ready to bolt in and go, but then to find it needs a couple hundred dollars worth of machine work plus whatever parts are needed just to get running, never mind any upgrades he was thinking about, is frustrating.
Old Jun 19, 2010 | 07:41 PM
Jordan927's Avatar
He could always try and look for another block only....should get a good one that just needs a hone and rings for under 300 bones...if this one is out of spec
Old Jun 19, 2010 | 08:03 PM
Atomic's Avatar
hmm, interesting thought.
Old Jun 19, 2010 | 09:16 PM
1LOW4X4's Avatar
Banned
I was gonna say all that but figured it was pointless. If you are gonna do it then spend the money and do it right. But I can also see where he would be disappointed in all the work that needs to be done.
Still, **** happens and you work around it. Its amazing all the money I can hustle on the side when **** goes bad and I have to find another way.....gives me motivation
Old Jun 19, 2010 | 09:38 PM
SincalT/A's Avatar
Summit sells speed pro stock replacement pistons for bout 25 a pop.
Old Jun 19, 2010 | 09:58 PM
SincalT/A's Avatar
Piston part#H857CP
Rings#E921K
Old Jun 19, 2010 | 10:05 PM
1LOW4X4's Avatar
Banned
well depending on what he wants to do with the motor (boost, nos) If I was gonna replace pistons Id forge. Again, way more money.
