-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   DIY Catch Can Install (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/diy-catch-can-install-548384/)
badbowtie15 Mar 21, 2017 11:30 PM
After much research, I decided that my LQ9 could benefit from a catch can and that I could make an effective one while saving a few bucks. A lot of credit to guys on LS1tech and Morphs on the Grrrr8 forum. I purchased an Ebay 'catch can' and modified it with parts from my local Lowes store. All said and done, I have right around $50 bucks invested in this set up including the purchase of the catch can.
Here's the Ebay can I purchased:https://cimg7.ibsrv.net/gimg/www.per...0aca77352b.jpg
Not much to see on the inside:
https://cimg9.ibsrv.net/gimg/www.per...66a23ffd3d.jpg
I then made a template out of cardboard to get the dimensions:
https://cimg0.ibsrv.net/gimg/www.per...a387b5103b.jpg
And then turned that into the buffer/baffle using .025" steel:
https://cimg1.ibsrv.net/gimg/www.per...a0d23ca8c2.jpg
Added an inlet tube using copper pipe attached to the inlet port:
https://cimg3.ibsrv.net/gimg/www.per...8a3d56ff64.jpg
Used the ole trusty JB weld to install and seal buffer/baffle in the can:
https://cimg4.ibsrv.net/gimg/www.per...c3167033d7.jpg
And added stainless steel scrubber material in the outlet side to promote condensation of oil vapor:
https://cimg5.ibsrv.net/gimg/www.per...147e63ecbd.jpg
I attached my catch can with some spare brackets, nuts and bolts I had laying around to the alternator bracket and ran my 3/8" PVC hose.
Pics of catch can installed:
https://cimg7.ibsrv.net/gimg/www.per...9d259fcc5f.jpg
https://cimg8.ibsrv.net/gimg/www.per...517205a83c.jpg
https://cimg9.ibsrv.net/gimg/www.per...d3a5d7a991.jpg
Brianwilson1990 Mar 21, 2017 11:58 PM
Looks good. My next mod will be a huge glass catch can. Because I am forgetful and I want to see the oil in it. Not sure where I will find one. BUT I will.
colekill Mar 22, 2017 12:23 PM
use a mason jar?
53bowtie Mar 22, 2017 01:40 PM
Nice write up. How did you plumb it? I have seen several different ways so just curious.....
Slow05CC Mar 22, 2017 04:46 PM
Well done! The catch can is the next modification on my list.
badbowtie15 Mar 22, 2017 08:03 PM
Back of driver side valve cover to inlet of catch can, outlet of catch can to the port on the top of stock 03 NBS intake manifold.
Brianwilson1990 Mar 23, 2017 04:49 PM
Exactly what he said. No other right way. Lots of other wrong ways.
