dirtydingo ALT/PS bracket posible problem ??
1 Attachment(s)
will I'm building a 408 for my friend just recived the rototing from FedEX , and while I was looking at heads to buy , I contacted Richard @WCCH and told him what my set up was
I also told him that I bought the Holley Hi Ram intake he said that this is a max effort max cubes intake and wont work will in my buddy's setup so I canceld the Intake now , I want to bolt somthing else to the heads , the carb style intake is also not that good of a DD so I went to the fast , but im going to have a problem with the alternator water pump nick went to the dirty dingo website for a solution and found this bracket Attachment 127516 as you can see there is just not enough contact area for the belt on the crank pulley, it might have some sliping with WOT pulls or or fast engine rev's not to mention supercharger so am I right thinking that way or not? here is the stock bracket and you can see the contact area on the crank pulley http://www.billavista.com/tech/Artic...0SLH%20LoR.jpg its like the dirty dingo is covering 25% and the OEM is covering 60-80% of the pulley |
If your worried about hood clearance use the corvette acc drive. Pulley is $65, alt bracket is $75, a few other parts and it would be good to go. Total cost for the setup is about $250
im not worried about the hood clearnce , part numbers for these parts please
Got them at work, send me a pm Monday.
allright thanks bud
