Cylinder Head Choices
Old 12-08-2017, 03:06 PM
hunterbohanan23's Avatar
Default Cylinder Head Choices
Hey guys, I’m looking for some recommendations for a cylinder head shop to port my 243’s. I’m looking at TEA Stage 1 for $1350 or so. Which seems like a great deal since they come with .650 springs and retainers also. I won’t pull the trigger until just after the new year for my build. I’d like to stick with stock valves and intake ports in the 22x range. Build is a LS1/6 freshened up. Cam selection is probably Tick Performance TorqueMAX stage 2 for the LS1/6 which is a 227/235 .618/.605 LSA 110+3. 1996 c1500 swapped just looking for a good street build with a solid torque curve.
Old 12-08-2017, 03:53 PM
TXsilverado's Avatar
TEA or Advanced induction are great choices for 243 programs.
Or sell your 243 for 400 and get some as cast 220 heads.
Old 12-08-2017, 06:25 PM
gonzo 6.2's Avatar
How much lift can you put to those flat tops?
Old 12-08-2017, 06:39 PM
what makes the as cast a good option? are they able to have better porting potential than what my stock 243’s could be ported to with stock casting? not bad for the price but the TEA’s still flow a little better, which again, i understand it isn’t the only thing to look at.
Old 12-09-2017, 06:25 AM
As cast is a great bang for buck. Port work on them would lose the bang for buck. Maybe some light hand work. The aftermarket cast is stronger with less valve angle for less shrouding with a larger valve.
Talk to tea and ask their opinion on ported 243 vs as cast. Let them know you already have a core 243. They will shoot you straight.
Tea used to own trick flow, or still have some kind of affiliation....i cant remember the relationship off the top of my head.
KleanKustoms
10-14-2015 09:50 PM
99MedBlueBird
09-01-2013 12:33 PM
lukn4trbl355
01-18-2013 08:51 AM
OneQwikSS
01-05-2012 07:53 AM
99 Blue Z71
05-05-2004 09:16 PM
Quick Reply: Cylinder Head Choices
