-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Custom Grind, advice? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/custom-grind-advice-133343/)
Deckhand Jan 27, 2004 10:52 PM
Ok, I have talked to a few people including about these cams and now I have decided to maybe get a custom grind cam.
I would like somthing with a good torque, strong midrange and enough top end to shift at 6000rpms. Aggressive lope is also a good thing.
I have took the two of comps mild ls1 cams, and changed the LSA on them to achieve the aggressiveness im looking for.
1) 212/218 .522 .529 112 LSA
2) 212/218 .558 .563 112 LSA
Now which one would offer the most performance gains, while at least retaining low-end torque. I dont really want to lose low-end grunt but I have to, I would like to keep it to a minimum. This is also my one and only daily driver.
What would be the main difference performance wise between the cams? And what would you recommend?
thanks guys.
-joseph
BigTex Jan 27, 2004 11:07 PM
Be just a little different: 212/215 .558 .559 113lsa +3 advance :)
Flyer Jan 27, 2004 11:21 PM
I think the 1st one is gonna retain the better low end. There really isn't gonna b e much difference in those 2.
If you go to a 114lsa, you will have a better low end, but at the cost of a little idle chop.
BigTex Jan 27, 2004 11:25 PM
I agree w/ flyer on the 114 lsa, but I suggested the 113 to give more lope like was requested, but keep more low end than a 112. Also, droping a little exhaust duration will keep a tad more low end. Plus, going with the aggressive lobes will suprise you with the retained low end TQ but increased upper rpms HP.
