Cruise Control Effect(BIG TEX edit guru)
Old Aug 29, 2004 | 12:23 PM
jlwz71's Avatar
Default Cruise Control Effect(BIG TEX edit guru)
Any body else have this? I can't seem to shake it. Tried adjusting running airflow down and all that did was make it die going from drive to reverse. Any tips or suggestion. I have a small Crane Cam 113 LSA, stock tb hole and the other usual mods. Intake, headers etc. I have edit and have gutted the cats and removed egr and have larger 2004 injectors and scaled accordingly. I did not need to modify any VE tables. The truck runs excellent except for when I lift of throttle at 30 mph I can cruise down the street withour having to give it the gas. I still have the stock tourqe converter and am planning to upgrade to a TCI 3000 in the future. Is the stock converter to tight? I had to increase the idle to 625 in gear for drivability purposes. Maybe with the higher in gear idle the stock converter is to tight. Any thoughts or opinions, ideas, instruction?
Oobray
Jun 13, 2022 03:38 AM
99bluefirebird
Sep 17, 2015 08:05 PM
MA$TER_E
Sep 9, 2015 03:14 PM
Alco
Sep 4, 2015 04:08 PM
Ketis
Jul 23, 2015 12:37 PM
