Crank pulley pin for Radix install
Old May 5, 2005 | 04:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by Baumgardner2051
Sweet! Just because it says 2003-2004 on it, it is still good for the 2002 right?
I think I'll get them painted anyway and see how they turn out. Thanks again for the info.
The fuel pump will be different, and I think he has the upgraded heat exchanger.
Old May 5, 2005 | 05:40 PM
1SlowHoe's Avatar
Destroyer of Transmissions
The fuel pump is different in the new directions because they were changed for the 2003 model? The pump that came from Vince's kit will work with my set up correct? Is there a visual difference in the heat exchangers, because the one I got looks just like the one in the directions. You can e-mail me if you want at b10@mchsi.com.
Old May 5, 2005 | 08:45 PM
BlownChevy's Avatar
blownerator
25 Year Member
Depending on the year of the truck.....what are you doing for a tune?
Old May 5, 2005 | 08:48 PM
1SlowHoe's Avatar
My Tahoe is a 2002, so I figured the fuel pump would work. I have a Westers tune sitting in the garage waiting to go in after the S/C Question off topic kinda: are the injectors built into the radix bigger than stock? 44 lbs?
Old May 5, 2005 | 08:50 PM
moregrip's Avatar
what a rush!
yes, and 42
Old May 5, 2005 | 08:54 PM
1SlowHoe's Avatar
Originally Posted by moregrip
yes, and 42
Can you forsee any issues with my install this Sunday? The radix I got came off a 2000 Silverado 4.8, going onto an 02 Tahoe 5.3. I have new gaskets, tune, 3.4" pulley and haven't decided on new plug wires yet. Brian was discussing the fuel pump, it might be different? Help! Don't want to get my motor torn apart to find I need more parts.
Old May 5, 2005 | 09:19 PM
moregrip's Avatar
what a rush!
if the pumps are different from truck to tahoe you may need a different fuel pump.
Best thing to do is call the Tech line at Magnacharger tomorrow and confirm.
Other than that, everything sounds in order. Good Luck...........besides theres plenty of us on here to help if you get in a pinch
bigsapper
Jul 28, 2015 12:56 AM
therock
Jul 25, 2015 09:23 AM
blownss27
Jul 20, 2015 08:59 AM
