-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Are the Crane Vinci both the same... (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/crane-vinci-both-same-247848/)
04BlackGmc Dec 9, 2004 11:40 AM
Just name difference.
Mr. Sandog Dec 9, 2004 12:12 PM
AFAIK, Crane makes Vinci cams to Vinci specs with Vinci lobe designs. But I am willing to be wrong on this.
Yelo Dec 9, 2004 01:03 PM
My Vinci 044 came with a Crane Cams grind card......so I'd say yes
cstchevy Dec 9, 2004 01:09 PM
I would agree with that, crane makes their cams but to their specs.
TurboBerserker Dec 9, 2004 02:13 PM
Vinci != Crane.
Joe Vinci is a local (orlando) speed shop owner (called Vinci High Performance strangely enough :))
He may use Crane cams, but I don't know for sure. Joe's a nice guy, though.
Yelo Dec 9, 2004 02:30 PM
Well, My 044 cam had a Crane grind card that listed the grind as an: HR-210/3121-2S-14 4A, which Crane on thier website lists as PN#1449555....and the specs are the same between the two
TurboBerserker Dec 9, 2004 02:33 PM
Maybe I misunderstood. I thought the question was whether VHP was owned by Crane.
I have no idea on the cams, but from what Yelo posts, sounds pretty likely, don't it :P
49er Dec 9, 2004 02:45 PM
Lobe Separation
Yelo: I'm a newbe thats been following your cam selection because I plan to use a simular approach in my 5.3L. I'm curious why you slected the 114* LSA instead of the 112* as in the CR1449571 cam? Whats the advantge of both?
Can you use the stock retainers with the 912 springs? Thanks
Yelo Dec 9, 2004 02:55 PM
Welcome !!!!
I chose the 114º lsa because of idle quality issues....the 112º would have had a slightly rougher idle and since my goals are 100% stock drivablity and keeping the wife happy the 114º seemed the better choice. Also...even though it doesn't really pertain to me because of the county I live in...the 114º will pass smog better because of the reduced overlap.
As for the 912 springs....that's a HONDA valve spring, I'm going to assume that you mean the 918's ?? If so, YES...you can use the stock retainers with the 918's
49er Dec 9, 2004 03:42 PM
Welcome !!!!
Thank you for the information, yes, typing error...918's. No I dont think you need to worry about emissions where you are. I spent many years with Calif. Guard at Iwrin a long time ago . One more question: Will you use stock rockers and rods? Thanks for your help
