convert non flex-fuel to flex-fuel?
So YOUR the cause of my bread and groceries going up..... Uh huh...yep. I see how you are
I'd switch to a hot cam. The pollution level would be the same as burning ethanol.
Resident Retard
I checked into this a little while ago... Your non-flex truck is not wired for flex... YOu need to run a wire from the Compostion sensor to the PCM (Pin 56 on the C1 connector), also your tune needs to be adjusted for the flex inputs, sensor tests, and fueling tables modified... Not to mention buying a few fuel lines and the composition sensor...
jscherbs
03-24-2017 07:20 PM
jtphelps289
09-11-2015 06:37 PM
