Colder plugs cause P0300?
Old Feb 4, 2013 | 12:24 PM
Ferocity02's Avatar
Default Colder plugs cause P0300?
Just curious if colder spark plugs (TR6's) could cause a random cylinder misfire code P0300? I put in the TR6's because I am going turbo soon, gapped at 0.035 I believe. Had TR55's gapped at 0.055 before without any issues. Same plug wires and coils. I cleared the code to see if it will come back but I've only driven it twice since.
Old Feb 4, 2013 | 12:27 PM
chevrolet all the way's Avatar
not a fan of projected tip for boost as a side note, but it can happen. i tried to go from tr6 to tr7 with my old nitrous setup and it would set miss codes
Old Feb 4, 2013 | 12:53 PM
chevyboy.520's Avatar
i would recommend the br7ef. its non projected tip. good for boost. part number is 3346
Old Feb 9, 2013 | 11:51 PM
Evil Eric's Avatar
there shear number of customers coming into my store for oxy sensors and requesting to have codes read for p0300 is bafleing this winter. nothing like this happened the last 2 winters. im wondering f something is up with the ethanol blend in the fuel in this region thats doing this to vehicles. Im talking everything from inline 4 bangers to LS2's having the same issue.
Old Feb 10, 2013 | 03:43 AM
Suburbazine's Avatar
Ethanol doesn't burn well when cold. Vehicles not designed with E-fuel in mind may run poorly in cold weather.
In my truck, on a 40 degree day, cold start with E85, it stumbles and misses for the first 30 seconds. After that it smooths out...but it's designed and programmed for E85.
Old Feb 10, 2013 | 07:28 AM
GMCtrk's Avatar
Check and see what C5606 is set to. Set it to 1500 if it's not already similar.
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
